[petsc-dev] DMGetNamedGlobalVector() implementation?
Thu Jul 19 13:25:58 CDT 2012
On Thu, Jul 19, 2012 at 1:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Why not implement it using PetscObjectQuery()/PetscObjectCompose()? and
> not have to introduce a whole new datatype DMNamedVecLink linked list and
> other crap?
The only reason this thing has to exist, and it really has to exist in some
form, is that we have a reference loop. For example, the SNES Vec X is
obtained from the DM (thus X references the DM), but must be made available
to the KSP callback that uses the DM. If we attached X to the DM, then we
would have a loop X -> DM -> X. Same for the TS vector needed in
SNESComputeFunction.
The general form of PetscObjectCompose allowing reference loops is terribly
dangerous and imprecise (you end up implementing a sort of limited garbage
collector that periodically looks for loops, but that is super dangerous in
parallel because you need determinism in destruction).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120719/a44c8a24/attachment.html>
