[petsc-dev] where is type(Mat) defined?
Wed Jul 18 17:00:31 CDT 2012
I've changed the filename to 'zmatnullf.c' - per convention - and
commited to petsc-3.3 [and merged to petsc-dev]
Satish
On Wed, 18 Jul 2012, Barry Smith wrote:
>   Satish,
>     Please apply this patch if it makes sense.
>    Thanks
>    Barry
> On Jul 17, 2012, at 11:25 PM, Blaise Bourdin wrote:
> > On Jul 17, 2012, at 10:51 PM, Barry Smith wrote:
> >> If you are using Fortran modules (and being a FORTRAN lover you are :-). Then you have to rebuild the modules whenever you change these files.  Do make cmake after you edit the file
> > You bet I am...
> > make cmake is what I was missing.
> > Is it possible to apply the attached patch to petsc-3.3 and petsc-dev?
> > It adds the data type, and the fortran binding for MatNullSpaceView.
> > Blaise
> > <MatNullSpace.patch>
> >>  Barry
> >> On Jul 17, 2012, at 10:41 PM, Blaise Bourdin wrote:
> >>> Hi,
> >>> I am still trying to figure out how to add support for MatNullSpace with fortran data types. As I said in a previous email, adding the statement
> >>>    type MatNullSpace
> >>>      PetscFortranAddr:: v
> >>>    end type MatNullSpace
> >>> in include/finclude/ftn-custom/petscmatdef.h90
> >>> is not enough.
> >>> Furthermore, if I remove the corresponding statement
> >>>    type Mat
> >>>    end type Mat
> >>> for Mat, I can still compile code with a statement like
> >>> Type(Mat) :: M
> >>> It looks like the fortran data type for Mat is defined somewhere else, but I can't figure out where. Can anybody shine some light for me?
> >>> Blaise
> >>> Department of Mathematics and Center for Computation & Technology
> >>> Louisiana State University, Baton Rouge, LA 70803, USA
> >>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
