[petsc-dev] where is type(Mat) defined?
Wed Jul 18 14:19:08 CDT 2012
  Satish,
    Please apply this patch if it makes sense.
   Thanks
   Barry
On Jul 17, 2012, at 11:25 PM, Blaise Bourdin wrote:
> On Jul 17, 2012, at 10:51 PM, Barry Smith wrote:
>> If you are using Fortran modules (and being a FORTRAN lover you are :-). Then you have to rebuild the modules whenever you change these files.  Do make cmake after you edit the file
> You bet I am...
> make cmake is what I was missing.
> Is it possible to apply the attached patch to petsc-3.3 and petsc-dev?
> It adds the data type, and the fortran binding for MatNullSpaceView.
> Blaise
> <MatNullSpace.patch>
>>  Barry
>> On Jul 17, 2012, at 10:41 PM, Blaise Bourdin wrote:
>>> Hi,
>>> I am still trying to figure out how to add support for MatNullSpace with fortran data types. As I said in a previous email, adding the statement
>>>    type MatNullSpace
>>>      PetscFortranAddr:: v
>>>    end type MatNullSpace
>>> in include/finclude/ftn-custom/petscmatdef.h90
>>> is not enough.
>>> Furthermore, if I remove the corresponding statement
>>>    type Mat
>>>    end type Mat
>>> for Mat, I can still compile code with a statement like
>>> Type(Mat) :: M
>>> It looks like the fortran data type for Mat is defined somewhere else, but I can't figure out where. Can anybody shine some light for me?
>>> Blaise
>>> Department of Mathematics and Center for Computation & Technology
>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
