[petsc-dev] second patch for DMDAVecGetArrayF90
Blaise Bourdin bourdin at lsu.edu
Fri Jul 6 06:30:16 CDT 2012
I have added the creation, destruction and accessor functions for 4d vectors in F90. The accessor was missing and needed for DMDAVecGetArrayF90 with a 3d DMDA and >1 dof. As far as I can test, ex11f90 in DM should now completely work with the intel compilers.
Some of the functions are probably not used (F90Array4dAccessReal, F90Array4dAccessInt, F90Array4dAccessFortranAddr, for instance), but I added them anyway. Let me know if you want me to submit a patch without them.
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120706/7033fe80/attachment.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
