[petsc-dev] who did this?
Thu Jul 5 15:06:35 CDT 2012
On Thu, Jul 5, 2012 at 10:37 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jul 5, 2012 at 5:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Jul 5, 2012, at 4:19 AM, Jed Brown wrote:
>> > This is years old, but in any case, fixed now:
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/30f9a34e118e
>>    How can it possibly be years old? You're saying that this message has
>> appeared every night during the nightly tests and every time someone did
>> make alltests and during every test Satish made before the release?
> Oops, I read "hg annotate" incorrectly. It was in
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/2ab3e57475d7
> which was merged in
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/9dfe4a92ca2c
> I don't understand the motivation for unrolling the shell loop, but then
> referencing a file that doesn't match the target name.
I unrolled the shell loop so that the shell code can be processed by
Python, and eventually converted to Python tests.
    Matt
>> > On Wed, Jul 4, 2012 at 10:17 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > /bin/sh: -c: line 0: syntax error near unexpected token `done'
>> `/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpiexec -n 1 ./ex37
>> -explicit_is 0 > ex37_1.tmp 2>&1;    /usr/bin/diff -w output/ex37_1.out
>> ex37_1.tmp || echo
>>  /Users/barrysmith/Src/petsc-dev/src/vec/vec/examples/tests "\nPossible
>> problem with ex37_1, diffs above
>> \n=========================================";   done; /bin/rm -f -f
>> ex37_1.tmp'
>> > make[7]: [runex37] Error 2 (ignored)
>> -explicit_is 1 > ex37_1.tmp 2>&1;    /usr/bin/diff -w output/ex37_1.out
>> ex37_1.tmp || echo
>> ex37_1.tmp'
>> > make[7]: [runex37_1] Error 2 (ignored)
>> `/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpiexec -n 2 ./ex37
>> -explicit_is 0 > ex37_2.tmp 2>&1;    /usr/bin/diff -w output/ex37_2.out
>> ex37_2.tmp || echo
>> problem with ex37_2, diffs above
>> ex37_2.tmp'
>> > make[7]: [runex37_2] Error 2 (ignored)
>> > At least test your rule before pushing
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120705/e1fd77ee/attachment.html>
