[petsc-dev] petsc-dev very broken
Sun Jan 22 09:38:16 CST 2012
On Sat, Jan 21, 2012 at 8:44 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Jan 21, 2012 at 20:37, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   We cannot have MatPreallocated() inside MatSetValues() because
>> MatSetValues() is not collective but MatPreallocated() ->
>>  MatSetUpPreallocation() -> MatMPIAIJSetPreallocation() is collective.
>>   Likely this bug has been around a long time but Jed's changes to
>> preallocation business has exposed it.
> At has been there since the beginning of time (revision 0).
>>   How to fix?
>> 1)       Error out if non preallocated matrix sent to MatSetValues()?
>> Yuck?  Cause this means user must then always call MatPreallocated() or
>> MatSetUp() before ever using it.
>>               MatCreate()
>>               MatSetSizes()
>>               MatSetType()
>>               MatSetUp()   or MatXXXSetPreallocation() or
>>               use
> Unfortunately, I think this is the only viable choice.
>> 2)       Pray every one always calls MatSetValues() on each process if
>> not preallocating and make sure internally we never screw up. Yuck.
> I fear that this causes deadlock only when someone strong scales the job
> up to where they get an empty process. That is the kind of bug that is hard
> to find and can burn too many cycles to risk.
I think we should try to draw out the complete state machine for Mat. This
of-the-cuff reasoning obviously does not
work when things get complicated.
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120122/8b524b5b/attachment.html>
