[petsc-dev] petsc-dev very broken
Sat Jan 21 20:44:01 CST 2012
On Sat, Jan 21, 2012 at 20:37, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   We cannot have MatPreallocated() inside MatSetValues() because
> MatSetValues() is not collective but MatPreallocated() ->
>  MatSetUpPreallocation() -> MatMPIAIJSetPreallocation() is collective.
>   Likely this bug has been around a long time but Jed's changes to
> preallocation business has exposed it.
At has been there since the beginning of time (revision 0).
>   How to fix?
> 1)       Error out if non preallocated matrix sent to MatSetValues()?
> Yuck?  Cause this means user must then always call MatPreallocated() or
> MatSetUp() before ever using it.
>               MatCreate()
>               MatSetSizes()
>               MatSetType()
>               MatSetUp()   or MatXXXSetPreallocation() or
>               use
Unfortunately, I think this is the only viable choice.
> 2)       Pray every one always calls MatSetValues() on each process if not
> preallocating and make sure internally we never screw up. Yuck.
I fear that this causes deadlock only when someone strong scales the job up
to where they get an empty process. That is the kind of bug that is hard to
find and can burn too many cycles to risk.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120121/5630ce5b/attachment.html>
