[petsc-dev] This has officially become too ugly to read
Fri Jan 20 16:51:01 CST 2012
On Fri, Jan 20, 2012 at 4:45 PM, Paul Mullowney <paulm at txcorp.com> wrote:
> The new code using CUSPARSE gives you triangular solves that are supported
> by Nvidia. They are as fast as what was in their previously. Advantage is
> that it's now fully supported by the vendor library.
> The matrix multiplication is more succinct than what was in petsc-dev.
> Plus it has options for choosing storage format on the device for optimal
> performance.
> You now have csr/coo/ell/dia formats ... Plus the SpMV scales across
> multiple GPUs now.
> I am happy to remove printf's if that helps.
Although, I care in the abstract about how code looks, I don't have enough
time to complain about it. I care in this case,
because it does not appear to be supportable by us. If this is not true,
and someone understands all this, please say so.
Then I will go back to not caring.
    Matt
> -Paul
> On Fri, Jan 20, 2012 at 4:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Jan 20, 2012, at 4:31 PM, Matthew Knepley wrote:
>> > http://petsc.cs.iit.edu/petsc/petsc-dev/rev/2a4f352daf49
>> > What is going on here, and why can't it be done more succintly?
>>    Hell its GPUs, what do you expect?
>>   What particularly part do you feel is overly complex and could be more
>> succintly?
>  This checkin of fixes is larger than the entire prior implementation.
> Why, what is better?
>  There are a ton of new functions with obscure names (unless Some has a
> meaning which
> escapes me).
>  There seem to be a huge number of cases treated in enormous functions
> rather than
> factoring them out.
>     Matt
>>   Barry
>> >     Matt
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120120/7534e684/attachment.html>
