[petsc-dev] hdf5.py is messed up
Sean Farley sean at mcs.anl.gov
Thu Jan 19 09:54:45 CST 2012
> HDF5 in their infinite wisdom run tests in the same make target as the
> build. One of the Fortran
> tests breaks on the Mac. The only solution that worked for me was to
> disable that test with a
> patch for the source. I mailed them this problem with no response. Feel
> free to fix this in a way
> that satisfies you aesthetically.
I run version 1.8.8 and haven't had anything blow up when making tests.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120119/9d069d65/attachment.html>
