[petsc-dev] hdf5.py is messed up
Thu Jan 19 09:05:30 CST 2012
On Thu, Jan 19, 2012 at 8:06 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   hdf5.py is messed up, it starts with crap from a patch??? Please fix
HDF5 in their infinite wisdom run tests in the same make target as the
build. One of the Fortran
tests breaks on the Mac. The only solution that worked for me was to
disable that test with a
patch for the source. I mailed them this problem with no response. Feel
free to fix this in a way
that satisfies you aesthetically.
   Matt
> import config.package
> import os
> testPatch = '''\
> Index: fortran/test/tH5Sselect.f90
> --- fortran/test/tH5Sselect.f90 2011-10-20 09:37:20.000000000 -0400
> +++ fortran/test/tH5Sselect.f90 2011-10-20 09:38:22.000000000 -0400
> @@ -1884,13 +1884,13 @@
>   CALL check("H5Soffset_simple_f", error, total_error)
>   ! /* Set "regular" hyperslab selection */
> -  start(1:2) = 2
> +  !start(1:2) = 2
>   stride(1:2) = 10
>   count(1:2) = 4
>   block(1:2) = 5
> -  CALL h5sselect_hyperslab_f(sid, H5S_SELECT_SET_F, start, &
> -       count, error, stride, block)
> +  !CALL h5sselect_hyperslab_f(sid, H5S_SELECT_SET_F, start, &
> +  !     count, error, stride, block)
>   CALL check("h5sselect_hyperslab_f", error, total_error)
>   !/* Get bounds for hyperslab selection */
> @@ -1931,13 +1931,13 @@
>   ! /* Make "irregular" hyperslab selection */
> -  start(1:2) = 20
> +  !start(1:2) = 20
>   stride(1:2) = 20
>   count(1:2) = 2
>   block(1:2) = 10
> -  CALL h5sselect_hyperslab_f(sid, H5S_SELECT_OR_F, start, &
> +  !CALL h5sselect_hyperslab_f(sid, H5S_SELECT_OR_F, start, &
> class Configure(config.package.Package):
>  def __init__(self, framework):
>    config.package.Package.__init__(self, framework)
>    self.download     = ['
> http://ftp.mcs.anl.gov/pub/petsc/externalpackages/hdf5-1.8.6.tar.gz']
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120119/cf343c5e/attachment.html>
