[petsc-dev] Barry, why would you do such a thing?
Wed Jan 18 10:15:46 CST 2012
On Thu, Jan 5, 2012 at 11:21, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/3e8229e78095
> I'm having trouble understanding the justification that you gave in the
> commit message...
> Also, that comment format is not allowed in PETSc code.
So now Peter has fixed the comment syntax in (
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/113ebf3872d3), but we still
have this confusing fragment of dead code floating around. Is the error
handler really not supposed to be set? Was this a debugging fragment that
never should have been committed? What's going on here? (I want to either
delete the line or uncomment it.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120118/c51e2712/attachment.html>
