[petsc-dev] GMRES with one processor crashes
Alexander Grayver agrayver at gfz-potsdam.de
Fri Jan 13 04:41:53 CST 2012
I tested various combinations, for the error.
It appears only in this combination:
* debugging configuration
* MKL blas/lapack (but not blacs and scalapack!)
* development branch
The release configuration, reference blas/lapack installation or
petsc-3.2-p5 do not have the problem.
Alexander
On 11.01.2012 19:55, Matthew Knepley wrote:
> On Wed, Jan 11, 2012 at 11:10 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     The error still happens if I configure and make with the following
>     line:
>     ./configure --with-petsc-arch=openmpi-intel-complex-debug-c
>     --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
>     --with-scalar-type=complex
>     --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
>     --with-precision=double
> This sounds like a problem with the MKL install. Are the complex
> routines there and not just stubs? Is that
> the correct set of libraries for this machine?
>    Matt
>     And disappears with the following one:
>     --with-scalar-type=complex --download-blas-lapack
>     What could that mean?
>     Regards,
>     Alexander
>     On 10.01.2012 20:29, Matthew Knepley wrote:
>>     On Tue, Jan 10, 2012 at 4:27 AM, Alexander Grayver
>>         Can I do something about that I should I wait for patch?
>>     I was not being direct enough. I want you to repeatedly
>>     reconfigure and run until you find the
>>     offending package. We still cannot get this to fail.
>>        Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120113/a79cf9b2/attachment.html>
