[petsc-dev] GMRES with one processor crashes
Wed Jan 11 12:55:05 CST 2012
On Wed, Jan 11, 2012 at 11:10 AM, Alexander Grayver <agrayver at gfz-potsdam.de
> wrote:
> The error still happens if I configure and make with the following line:
> ./configure --with-petsc-arch=openmpi-intel-complex-debug-c
> --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
> --with-precision=double
This sounds like a problem with the MKL install. Are the complex routines
there and not just stubs? Is that
the correct set of libraries for this machine?
   Matt
> And disappears with the following one:
> --download-blas-lapack --with-precision=double
> What could that mean?
> Regards,
> Alexander
> On 10.01.2012 20:29, Matthew Knepley wrote:
> On Tue, Jan 10, 2012 at 4:27 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>>  Can I do something about that I should I wait for patch?
>  I was not being direct enough. I want you to repeatedly reconfigure and
> run until you find the
> offending package. We still cannot get this to fail.
>     Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120111/d47309e6/attachment.html>
