[petsc-dev] configure fails
Thomas Witkowski thomas.witkowski at tu-dresden.de
Wed Jan 11 03:06:14 CST 2012
Satish Balay wrote:
> Most common issues with metis/parmetis:
> - latest cmake is not in PATH [check 'which cmake; cmake --version']
> - latest gnumake is not in PATH [check 'make --version']
Thanks, this was exactly the problem. When I updated gnumake from 3.80
to 3.82, configure and compilation of petsc-dev worked fine!
Thomas
