[petsc-dev] GMRES with one processor crashes
Mon Jan 9 06:26:32 CST 2012
On Mon, Jan 9, 2012 at 5:45 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Hi Jed,
> On 09.01.2012 12:34, Jed Brown wrote:
> On Mon, Jan 9, 2012 at 05:23, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
>> I run petsc-dev like that:
>> mpirun -n 2 /home/solveTest -ksp_view -ksp_monitor -ksp_converged_reason
>> -ksp_monitor_true_residual -log_summary -mat_type mpiaij -ksp_rtol 1.0e-12
>>  But just switching to one process (-n 1) makes it crashing:
>  Try removing the "-mat_type mpiaij" part. Note that you can still use
> "-mat_type aij". Also note that you should usually use a prefix so that you
> are setting the type of a specific matrix instead of setting the type of
> all matrices (for which MatSetFromOptions() is called).
> There is only one matrix in application. It is very simple one, the test
> just loads system matrix and rhs and solves system. I want to use it to
> test different solvers/preconditioners.
Note that KSP ex10 does exactly this. Does it crash? This could be a BLAS
incompatibility of some sort.
   Matt
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
> Please run with valgrind --db-attach=yes (or at least a debugger) to get a
> stack trace.
> This is the stack trace:
>      zdotc,               FP=7fffa35afce0
> VecNorm_Seq,         FP=7fffa35afe40
> VecNorm,             FP=7fffa35aff80
> VecNormalize,        FP=7fffa35b0080
> GMREScycle,          FP=7fffa35b02e0
> KSPSolve_GMRES,      FP=7fffa35b0390
> KSPSolve,            FP=7fffa35b1ef0
> main,                FP=7fffa35b31d0
> It crashes here:
>    PetscFunctionBegin;
>    if (type == NORM_2 || type == NORM_FROBENIUS) {
>      ierr = VecGetArrayRead(xin,&xx);CHKERRQ(ierr);
>      *z = BLASdot_(&bn,xx,&one,xx,&one);  // <<<< crash
> The log from valgrind is attached, but it is completely filled with stupid
> MPI messages. How could one filter out all that stuff?
> Regards,
> Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/05ddb447/attachment.html>
