[petsc-dev] GMRES with one processor crashes
Alexander Grayver agrayver at gfz-potsdam.de
Mon Jan 9 05:54:05 CST 2012
Sorry, I don't quite understand what you mean by first error was earlier?
Yes, symbols are on and I found the crash-related part in the log file.
See it attached.
Alexander
On 09.01.2012 12:51, Jed Brown wrote:
> The first error was likely earlier.
> Do you have debugging symbols turned on?
> Valgrind has options to write exception files for false positives.
> MPICH is usually valgrind-clean while Open MPI is quite noisy.
> I will look at the log when I have a computer.
> On Jan 9, 2012 5:47 AM, "Alexander Grayver" <agrayver at gfz-potsdam.de
> <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Hi Jed,
>     On 09.01.2012 12:34, Jed Brown wrote:
>>     On Mon, Jan 9, 2012 at 05:23, Alexander Grayver
>>     <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>>         I run petsc-dev like that:
>>         mpirun -n 2 /home/solveTest -ksp_view -ksp_monitor
>>         -ksp_converged_reason -ksp_monitor_true_residual -log_summary
>>         -mat_type mpiaij -ksp_rtol 1.0e-12
>>         But just switching to one process (-n 1) makes it crashing:
>>     Try removing the "-mat_type mpiaij" part. Note that you can still
>>     use "-mat_type aij". Also note that you should usually use a
>>     prefix so that you are setting the type of a specific matrix
>>     instead of setting the type of all matrices (for which
>>     MatSetFromOptions() is called).
>     There is only one matrix in application. It is very simple one,
>     the test just loads system matrix and rhs and solves system. I
>     want to use it to test different solvers/preconditioners.
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>         Violation, probably memory access out of range
>>     Please run with valgrind --db-attach=yes (or at least a debugger)
>>     to get a stack trace.
>     This is the stack trace:
>          zdotc,               FP=7fffa35afce0
>     VecNorm_Seq,         FP=7fffa35afe40
>     VecNorm,             FP=7fffa35aff80
>     VecNormalize,        FP=7fffa35b0080
>     GMREScycle,          FP=7fffa35b02e0
>     KSPSolve_GMRES,      FP=7fffa35b0390
>     KSPSolve,            FP=7fffa35b1ef0
>     main,                FP=7fffa35b31d0
>     It crashes here:
>        PetscFunctionBegin;
>        if (type == NORM_2 || type == NORM_FROBENIUS) {
>          ierr = VecGetArrayRead(xin,&xx);CHKERRQ(ierr);
>          *z = BLASdot_(&bn,xx,&one,xx,&one);  // <<<< crash
>     The log from valgrind is attached, but it is completely filled
>     with stupid MPI messages. How could one filter out all that stuff?
>     Regards,
>     Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/b236cabe/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/b236cabe/attachment.txt>
