[petsc-dev] fortran modules and datatypes
Wed Jan 4 15:17:31 CST 2012
On Wed, Jan 4, 2012 at 15:13, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Is there a preprocessor variable indicating if petsc is compiled with
> fortran modules? I would like to update some of these examples following
> the lines of src/vec/vec/examples/tutorials/ex20f90.F90
> cf attached patch for src/vec/examples/tutorial/ex1f90.F
>From the patch, I assume you already know about these?
PETSC_USE_FORTRAN_INTERFACES
PETSC_USE_FORTRAN_DATATYPES
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120104/b1ad5e25/attachment.html>
