[petsc-dev] petsc-dev on bitbucket
Stefano Zampini stefano.zampini at gmail.com
Mon Feb 27 16:07:15 CST 2012
I just pushed to bitbucket and my write permissions were revoked.
2012/2/27 Jed Brown <jedbrown at mcs.anl.gov>
> On Mon, Feb 27, 2012 at 15:48, Satish Balay <balay at mcs.anl.gov> wrote:
>> Jed,
>> Perhaps this is a  test case for 'pull request' model? [via petsc.cs]
> Sure, Stefano (or anyone) can fork on bitbucket, hack away, then send a
> pull request. We can merge locally and push to petsc-dev (which will be
> mirrored to bitbucket and should close the pull request).
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/191ad9de/attachment.html>
