[petsc-dev] petsc-dev on bitbucket
Mon Feb 27 15:58:45 CST 2012
On Mon, Feb 27, 2012 at 15:48, Satish Balay <balay at mcs.anl.gov> wrote:
> Jed,
> Perhaps this is a  test case for 'pull request' model? [via petsc.cs]
Sure, Stefano (or anyone) can fork on bitbucket, hack away, then send a
pull request. We can merge locally and push to petsc-dev (which will be
mirrored to bitbucket and should close the pull request).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/f695f6a5/attachment.html>
