[petsc-dev] the complex dot business
Mon Feb 27 11:01:33 CST 2012
On Mon, Feb 27, 2012 at 10:55, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I'm afraid the sudden appearance of the blas dot for complex numbers
> problem is my fault.
>   Traditionally since 199x we never used the complex dot product from blas
> because of the return complex type problem. VecDot_Seq() used #ifdef for
> complex and a simple loop.
>   Since some blas norm suck I off-hand told Shri to use dot for norm and
> wasn't thinking the complex case.
Most BLAS implementations don't have great code for BLAS level 1 anyway and
it tends to be memory bandwidth limited, so I don't have a problem with
using a simple loop.
>   Since then, of course, the complex dot problem has been coming up.
>   Maybe it is best to continue to never use complex blas dot and just
> change the VecNorm_ routines to use norm for complex and not dot.? Just
> throw away this silly problem and time sink?
I think we should use norm for norm.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/f244e0e7/attachment.html>
