[petsc-dev] BuildSystem clean-up
Sean Farley sean at mcs.anl.gov
Fri Feb 24 11:10:43 CST 2012
> BTW: externalpackages/package/PETSC_ARCH is more like a default prefix
> for the package. Ideally if the package supported prefix - we would
> use it and put the stuff directly in PETSC_DIR/PETSC_ARCH - and
> externalpackages/package/PETSC_ARCH won't have any stuff in it.
Ah, ok, that makes sense now.
> Perhaps some package.py files are doing things manually and using
> externalpackages/package/PETSC_ARCH as temporary location - and later
> coping things over to PETSC_DIR/PETSC_ARCH - and not cleaning things
> up. [in externalpackages/package/PETSC_ARCH].
Right, but what should we do about it? It could potentially cause a bunch
of headaches.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/ff6ba6f9/attachment.html>
