[petsc-dev] Intel compilers + CUDA
Fri Feb 24 10:54:25 CST 2012
On Fri, Feb 24, 2012 at 10:51, John Fettig <john.fettig at gmail.com> wrote:
> Unfortunately it doesn't work.  I'll send the logs to petsc-maint, but
> here's the error.  If you remove these lines:
> #ifndef PETSC_HAVE___INT64
> #define PETSC_HAVE___INT64 1
> #endif
What system uses __int64? If we have stdint.h, we should use int64_t
because that is the standard.
> from $PETSC_ARCH/include/petscconf.h, it builds ok (and make test
> passes).  Here's the error:
> nvcc -O -arch=sm_20 -c --compiler-options=-fPIC
> -I/home/jfe/local/petsc-dev/include
> -I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include
> -I/usr/local/cuda/include
> -I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include/txpetscgpu/include
> -I/usr/local/encap/platform_mpi-8.01/include
> -D__INSDIR__=src/vec/vec/impls/seq/seqcusp/ veccusp.cu
> /home/jfe/local/petsc-dev/include/petscsys.h(219): error: identifier
> "__int64" is undefined
> John
> On Fri, Feb 24, 2012 at 10:53 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> --compiler-bindir <directory>               (-ccbin)
>>        Specify the directory in which the compiler executable (Microsoft
>>        Visual Studion cl, or a gcc derivative) resides. By default, this
>>        executable is expected in the current executable search path.
>> It says it will look for the default compiler in the specified path -
>> and doesn't mention that it can switch the compiler. Ah - the manpage
>> is misleading.. Looks like '--ccbin icc' works..
>> balay at bb30:~/junk>nvcc -v -ccbin icc sizeof.c
>> #$ _SPACE_=
>> #$ _CUDART_=cudart
>> #$ _HERE_=/usr/local/cuda/bin
>> #$ _THERE_=/usr/local/cuda/bin
>> #$ _TARGET_SIZE_=64
>> #$ TOP=/usr/local/cuda/bin/..
>> LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/usr/local/cuda/bin/../extools/lib:/soft/intel/11.0.081/lib/intel64:/soft/intel/11.0.081/lib/intel64:/usr/local/cuda/lib64:/usr/local/cuda/lib64
>> PATH=/usr/local/cuda/bin/../open64/bin:/usr/local/cuda/bin:/soft/intel/11.0.081/bin/intel64:/soft/intel/11.0.081/bin/intel64:/usr/mpi/gcc/mvapich2-1.5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/cuda/bin:/usr/local/cuda/bin
>> #$ INCLUDES="-I/usr/local/cuda/bin/../include"
>> "-I/usr/local/cuda/bin/../include/cudart"
>> #$ LIBRARIES=  "-L/usr/local/cuda/bin/../lib64" -lcudart
>> #$ CUDAFE_FLAGS=
>> #$ OPENCC_FLAGS=
>> #$ PTXAS_FLAGS=
>> #$ icc -c -x c "-I/usr/local/cuda/bin/../include"
>> "-I/usr/local/cuda/bin/../include/cudart"   -m64 -o
>> "/tmp/tmpxft_00000199_00000000-1_sizeof.o" "sizeof.c"
>> #$ icpc -m64 -o "a.out" -Wl,--start-group
>> "-L/usr/local/cuda/bin/../lib64" -lcudart -Wl,--end-group
>> So '--with-cc=icc' --with-nvcc='nvcc --ccbin icc' should work.. Will
>> check..
>> Satish
>> On Fri, 24 Feb 2012, John Fettig wrote:
>> > Some time ago I asked about using icc with nvcc.  You can use icc with
>> nvcc
>> > by passing it as an argument:
>> > nvcc -ccbin /path/to/icc
>> > Has anybody tried building PETSc with CUDA this way?
>> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/633b37c9/attachment.html>
