[petsc-dev] Intel compilers + CUDA
John Fettig john.fettig at gmail.com
Fri Feb 24 10:51:24 CST 2012
Unfortunately it doesn't work.  I'll send the logs to petsc-maint, but
here's the error.  If you remove these lines:
#ifndef PETSC_HAVE___INT64
#define PETSC_HAVE___INT64 1
#endif
from $PETSC_ARCH/include/petscconf.h, it builds ok (and make test passes).
Here's the error:
nvcc -O -arch=sm_20 -c --compiler-options=-fPIC
-I/home/jfe/local/petsc-dev/include
-I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include
-I/usr/local/cuda/include
-I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include/txpetscgpu/include
-I/usr/local/encap/platform_mpi-8.01/include
-D__INSDIR__=src/vec/vec/impls/seq/seqcusp/ veccusp.cu
/home/jfe/local/petsc-dev/include/petscsys.h(219): error: identifier
"__int64" is undefined
John
On Fri, Feb 24, 2012 at 10:53 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> --compiler-bindir <directory>               (-ccbin)
>        Specify the directory in which the compiler executable (Microsoft
>        Visual Studion cl, or a gcc derivative) resides. By default, this
>        executable is expected in the current executable search path.
> It says it will look for the default compiler in the specified path -
> and doesn't mention that it can switch the compiler. Ah - the manpage
> is misleading.. Looks like '--ccbin icc' works..
> balay at bb30:~/junk>nvcc -v -ccbin icc sizeof.c
> #$ _SPACE_=
> #$ _CUDART_=cudart
> #$ _HERE_=/usr/local/cuda/bin
> #$ _THERE_=/usr/local/cuda/bin
> #$ _TARGET_SIZE_=64
> #$ TOP=/usr/local/cuda/bin/..
> LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/usr/local/cuda/bin/../extools/lib:/soft/intel/11.0.081/lib/intel64:/soft/intel/11.0.081/lib/intel64:/usr/local/cuda/lib64:/usr/local/cuda/lib64
> PATH=/usr/local/cuda/bin/../open64/bin:/usr/local/cuda/bin:/soft/intel/11.0.081/bin/intel64:/soft/intel/11.0.081/bin/intel64:/usr/mpi/gcc/mvapich2-1.5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/cuda/bin:/usr/local/cuda/bin
> #$ INCLUDES="-I/usr/local/cuda/bin/../include"
> "-I/usr/local/cuda/bin/../include/cudart"
> #$ LIBRARIES=  "-L/usr/local/cuda/bin/../lib64" -lcudart
> #$ CUDAFE_FLAGS=
> #$ OPENCC_FLAGS=
> #$ PTXAS_FLAGS=
> #$ icc -c -x c "-I/usr/local/cuda/bin/../include"
> "-I/usr/local/cuda/bin/../include/cudart"   -m64 -o
> "/tmp/tmpxft_00000199_00000000-1_sizeof.o" "sizeof.c"
> #$ icpc -m64 -o "a.out" -Wl,--start-group
> "-L/usr/local/cuda/bin/../lib64" -lcudart -Wl,--end-group
> So '--with-cc=icc' --with-nvcc='nvcc --ccbin icc' should work.. Will
> check..
> Satish
> On Fri, 24 Feb 2012, John Fettig wrote:
> > Some time ago I asked about using icc with nvcc.  You can use icc with
> nvcc
> > by passing it as an argument:
> > nvcc -ccbin /path/to/icc
> > Has anybody tried building PETSc with CUDA this way?
> > John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/00168d40/attachment.html>
