[petsc-dev] Merge sets
Sun Feb 19 06:01:38 CST 2012
This is racy, we talked about it before.
On Feb 18, 2012 11:15 PM, "Sean Farley" <sean at mcs.anl.gov> wrote:
> Ah, I don't see it because the Python build uses md5. Doesn't cmake?
> I don't think 'make' is the annoyance here, at least, not to me. If I
> recall correctly, last time, Barry couldn't stand emac's insistence on
> asking 'should I reload this buffer' even when nothing changed on disk
> except for the timestamp. Following this thread:
> http://stackoverflow.com/questions/665600/how-can-i-get-emacs-to-revert-all-unchanged-buffers-when-switching-branches-in-g
> you can either set (global-auto-revert-mode) or try using the revbufs
> extension.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120219/cc080160/attachment.html>
