[petsc-dev] Merge sets
Sean Farley sean at mcs.anl.gov
Sat Feb 18 23:14:34 CST 2012
> Ah, I don't see it because the Python build uses md5. Doesn't cmake?
I don't think 'make' is the annoyance here, at least, not to me. If I
recall correctly, last time, Barry couldn't stand emac's insistence on
asking 'should I reload this buffer' even when nothing changed on disk
except for the timestamp. Following this thread:
http://stackoverflow.com/questions/665600/how-can-i-get-emacs-to-revert-all-unchanged-buffers-when-switching-branches-in-g
you can either set (global-auto-revert-mode) or try using the revbufs
extension.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120218/73a9af24/attachment.html>
