[petsc-dev] [petsc-maint #106126] petsc-dev not giving parmetis mpi information JED READ THIS
Sean Farley sean.michael.farley at gmail.com
Thu Feb 16 22:15:29 CST 2012
Yes, this is what I was working on but my time got blown away by other
things. Using the parmetis makefile is ridiculous.
On Thursday, February 16, 2012, Barry Smith wrote:
>   PETSc-folks
>     Actually why does parmetis.py even use that stupid gnumake file, we
> could change parmetis.py to issue the cmake builder command directly and
> then the make on the cmake generated makefile also directly and totally
> bypass that absurd makefile. Then we can have better control over what gets
> passed to the cmake builder and can pass down easily the needed include
> directories for MPI
>   Barry
> On Feb 16, 2012, at 10:00 PM, Barry Smith wrote:
> >  John,
> >   So I looked in the parmetis Makefile and it looks like it has no
> direct mechanism to pass in MPI include file directories etc. I do not know
> much about cmake the only way I could see getting that information in is via
> > ifneq ($(cflags), not-set)
> >    CONFIG_FLAGS += -DCMAKE_C_FLAGS:STRING="$(cflags)"
> > endif
> > but I don't know if this is a legitimate way in cmake to pass in include
> directories to cmake. JED?????
> > If the machine has MPI compiler wrappers (like most systems do) and you
> used that rather than passing icc and the MPI information to PETSc's
> ./configure that would also work.
> >   Barry
> > On Feb 16, 2012, at 11:58 AM, John Fettig wrote:
> >> Hello PETSc gurus,
> >> I'm trying to install petsc-dev using --download-parmetis=1, and it
> isn't
> >> passing any info that I give it about MPI to the parmetis configure.
> >> Looking at config/PETSc/packages/parmetis.py, it doesn't look like
> there is
> >> any attempt made to pass along this info.  Am I doing something wrong?
> >> (configure.log attached)
> >> Thanks,
> >> John
> >> <configure.log.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120217/dcb27131/attachment.html>
