[petsc-dev] PETSc GPU capabilities
Paul Mullowney paulm at txcorp.com
Fri Feb 10 21:57:28 CST 2012
We wrote a custom sparse triangular solve. In some case it performed a
little better (at most 15-20%). Sometimes it performed worse by a
similar amount. I may revive our custom solve at some point. For now,
Petsc only uses CUSPARSE.
-Paul
> Is this a custom sparse triangular solve or is it from CUSPARSE? If
> different, how does the performance compare with the CUSPARSE
> implementation?
