[petsc-dev] PETSc GPU capabilities
Fri Feb 10 16:24:19 CST 2012
On Fri, Feb 10, 2012 at 16:04, Paul Mullowney <paulm at txcorp.com> wrote:
> (2) Triangular Solve used in ILU preconditioners; i.e. MatSolve. The
> performance of this ... is what it is :|
Is this a custom sparse triangular solve or is it from CUSPARSE? If
different, how does the performance compare with the CUSPARSE
implementation?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/39fc772d/attachment.html>
