[petsc-dev] please make myself and Satish admin on bitbucket.org/petsc
Fri Feb 10 18:59:59 CST 2012
On Fri, 10 Feb 2012, Barry Smith wrote:
> > The model is:
> > you have an 'account' - and can create repos there. Now you are the
> > owner of the repos.
> > Then you can give 'admin' privilidges to other 'account' users on any
> > given repo. And also create groups to give read/write permissions
> > etc..
> > So they have this distinction of 'owner' vs 'admin' [and I think only
> > owner can delete repos]
>    Yes and I submit that model of owner and admin is fundamentally broken.   Sean claims he can set it up so more than one of us can access the petsc (owner account) but only using openid not the bitbucket password; this strange limitation is what provoked my why why why
Ah ok. Didn't realise this context.
Sounds like one can associate multiple 'open-id' accounts with a
single bitbucket account. And Sean must be suggesting - he would add
all 'open-id's for each of us to be able to login to 'petsc' account.
I suspect Sean created 'petsc' account with his openid account.  And
hence it doesn't have a passwd to share..
Satish
