[petsc-dev] please make myself and Satish admin on bitbucket.org/petsc
Fri Feb 10 18:43:26 CST 2012
On Fri, 10 Feb 2012, Satish Balay wrote:
> On Fri, 10 Feb 2012, Barry Smith wrote:
> >   I am totally confused. Why can I use my BarryFSmith account to admin repositories people make and push and pull repositories but suddenly when I want to have admin at the petsc level I need to use this other "openid" thing?????? Why, why why?
> Hmm openid is orthongonal. As I understand things - its just a
> machanism to not maintain yet-another-passwd-for-yet-another-site.
> [i.e setup openid with any openid provider. and then user this
> credential to login to accounts at 10 different sites. Obviously each
> site will track you as a different user - so they like to give you a
> user name].
> But you can ignore this - and do a userid/passwd just for bitbucket.
Should have added - if you've created 'BarryFSmith' account on
bitbucket using some openid account [for ex: your google account] -
then thats the authentication bitbucket will probably ask for -
whenever it need to autheticate you.
For ex: I created a regular account with a new passwd with bitbucket.
userid: balay
passwd: psswd
So it will provide bitbucket.org/balay/repo to me. For authentication
I just use the above userid/passwd.
If you've crated an account 'BarryFSmith' using an openid - say
bfsmith at google.com - with [google-passwd] - then it will provide
bitbucket.org/barryfsmith/repo. But for authetication - it will
always prompt you for the google-id and  google-passwd
Satish
> The model is:
> you have an 'account' - and can create repos there. Now you are the
> owner of the repos.
> Then you can give 'admin' privilidges to other 'account' users on any
> given repo. And also create groups to give read/write permissions
> etc..
> So they have this distinction of 'owner' vs 'admin' [and I think only
> owner can delete repos]
> Satish
