[petsc-dev] write access to petsc-dev bitbucket repo
Fri Feb 10 11:30:44 CST 2012
On Fri, Feb 10, 2012 at 11:28 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 10, 2012, at 11:25 AM, Matthew Knepley wrote:
> > On Fri, Feb 10, 2012 at 11:16 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > On Feb 10, 2012, at 11:06 AM, Matthew Knepley wrote:
> > > On Fri, Feb 10, 2012 at 11:04 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > sorry about the conflicting messages. We haven't yet completely
> > > switched to bitbucket. So please continue to push to iit repo.
> > > We have not decided that yet.
> >   We never decided to switch to bitbucket but suddenly we haven't
> decided to use petsc.cs.iit.edu?
> > I remember you telling Sean to put up the BB site, which happened before
> iit was back up.
>    Yes, I reminded him that since all hg repositories are equivalent that
> he could set up a petsc-dev that we could use since petsc.cs.itt.edu was
> down. No one decided at that instant it was to become the permanent one. If
> you remember we did this once or twice before in the past couple of years
> when petsc.cs.itt.edu was down.
>   BTW: I have found no records of bitbucket uptimes on their site or
> elsewhere so what evidence do you have to make your claim that it is more
> reliable (reliable meaning minutes per year where one can pull or push)?
Its anecdotal. I use both every day.
>   Barry
> > So, we have reduced the argument to:
> >   directories   vs.   better management, reliability, availability
> > If having directories is honestly a must-have for you, delete the BB
> site. If instead we are weighing
> > pros and cons, I think the choice is clear.
So you agree with this?
   Matt
> >     Matt
> > >   Matt
> > > thanks,
> > > Satish
> > > On Fri, 10 Feb 2012, Brad Aagaard wrote:
> > > > I have write access to the iit petsc-dev repo so that I can push
> fixes to
> > > > Matt's Sieve stuff. Matt had me switch over to the bitbucket repo
> and now I
> > > > don't have write access. I assume I need a bitbucket login, so I
> created one
> > > > (baagaard) and added my public ssh key. If one of you could enable
> write
> > > > access to the petsc-dev repo, I would appreciate it.
> > > > Thanks,
> > > > Brad
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/517b04c5/attachment.html>
