[petsc-dev] write access to petsc-dev bitbucket repo
Fri Feb 10 11:25:06 CST 2012
On Fri, Feb 10, 2012 at 11:16 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 10, 2012, at 11:06 AM, Matthew Knepley wrote:
> > On Fri, Feb 10, 2012 at 11:04 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > sorry about the conflicting messages. We haven't yet completely
> > switched to bitbucket. So please continue to push to iit repo.
> > We have not decided that yet.
>   We never decided to switch to bitbucket but suddenly we haven't decided
> to use petsc.cs.iit.edu?
I remember you telling Sean to put up the BB site, which happened before
iit was back up.
So, we have reduced the argument to:
  directories   vs.   better management, reliability, availability
If having directories is honestly a must-have for you, delete the BB site.
If instead we are weighing
pros and cons, I think the choice is clear.
    Matt
> >   Matt
> > thanks,
> > Satish
> > On Fri, 10 Feb 2012, Brad Aagaard wrote:
> > > I have write access to the iit petsc-dev repo so that I can push fixes
> to
> > > Matt's Sieve stuff. Matt had me switch over to the bitbucket repo and
> now I
> > > don't have write access. I assume I need a bitbucket login, so I
> created one
> > > (baagaard) and added my public ssh key. If one of you could enable
> write
> > > access to the petsc-dev repo, I would appreciate it.
> > > Thanks,
> > > Brad
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/e49f100e/attachment.html>
