[petsc-dev] write access to petsc-dev bitbucket repo
Sean Farley sean at mcs.anl.gov
Fri Feb 10 11:03:15 CST 2012
> I have write access to the iit petsc-dev repo so that I can push fixes to
> Matt's Sieve stuff. Matt had me switch over to the bitbucket repo and now I
> don't have write access. I assume I need a bitbucket login, so I created
> one (baagaard) and added my public ssh key. If one of you could enable
> write access to the petsc-dev repo, I would appreciate it.
OK, done.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/e2b6f89f/attachment.html>
