[petsc-dev] write access to petsc-dev bitbucket repo
Brad Aagaard baagaard at usgs.gov
Fri Feb 10 10:59:38 CST 2012
I have write access to the iit petsc-dev repo so that I can push fixes
to Matt's Sieve stuff. Matt had me switch over to the bitbucket repo and
now I don't have write access. I assume I need a bitbucket login, so I
created one (baagaard) and added my public ssh key. If one of you could
enable write access to the petsc-dev repo, I would appreciate it.
Brad
