[petsc-dev] MatMatMult gives different results
Thu Feb 9 21:44:45 CST 2012
On Thu, Feb 9, 2012 at 9:10 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 9 Feb 2012, Jed Brown wrote:
> > It's all workable,
> > but I'm not seeing a clear advantage to keeping the primary at
> > petsc.cs.iit.edu,
> currently the 2 reasons that are offered agains petsc.cs.iit.edu are:
> - ssh breaks - need https [to level comaprision - we can probably set
> this up for folks who want this]
> - reliability concerns.
> > (provided Sean volunteers to set up mirroring in that direction).
> Personally - I'd prefer not to deal with that. If its decided that
> bitbuckets is the thing ot use - we should disable petsc.cs.iit.edu,
> As you've noticed - mirroring has already caused confusion. And I
> suspect this will keep coming up - much more often than the frequence
> of a downed machine.
The master should be on Bitbucket. We could keep a repo at IIT that
is updated every time as a backup only if we need it, but for nothing else.
   Matt
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/5a4c74a5/attachment.html>
