[petsc-dev] MatMatMult gives different results
Thu Feb 9 20:37:22 CST 2012
On Thu, Feb 9, 2012 at 20:29, Satish Balay <balay at mcs.anl.gov> wrote:
> Is it possible to add such a trigger to bitbucket?
Yes
http://confluence.atlassian.com/display/BITBUCKET/Setting+Up+the+Bitbucket+POST+Service
> > The simple convenience of having https:// and
> > ssh:// trivially push/pull the same repository is enough to make me
> prefer
> > interacting with bitbucket (screwy networks filter ssh).
> Not sure what problems you had. The only known issue with ssh is - we
> have fail2ban running on petsc.cs.iit - and when there are ssh
> connections from misconfigured ip adresses [where dns lookup does not
> work - it thinks its a breakin attempt - and tries to ban that
> access].
No, the problem is goofy wireless networks. This bit Matt when he was at
Brown a few weeks ago and me in Istanbul last week. AFAIK, we have had to
decide for each repo whether to use ssh or https for pushing, so I can't hg
push https://petsc.cs.iit.edu/petsc/petsc-dev. Bitbucket supports both
simultaneously, and the user manages their credentials so you don't have to.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/9313d9a3/attachment.html>
