[petsc-dev] petsc-dev on bitbucket
Wed Feb 8 12:05:02 CST 2012
On Wed, Feb 8, 2012 at 11:32 AM, Sean Farley <sean at mcs.anl.gov> wrote:
> No I mean I want
>>   petsc/releases/petsc-3.1
>>   petsc/tools/parsing/BarrysNewHTMLMunger
> Sounds like you want a "traditional filesystem hierarchy" and like I said
> before, your request will fall on deaf ears. This is the same request that
> mercurial-dev gets from people switching from subversion: "I only want to
> check out a subdirectory, not the whole project!" to which the common
> response is, "You should rethink your 'project' if you only want a
> subdirectory." Take a look at subrepos and subpaths:
I guess I completely understand the logic for not checking out part of a
tree. There are consistency issues, and management
of related changes. However, I am just talking about grouping repositories.
I would be alright with any grouping strategy, be it
directories, tags, etc. I think this is orthogonal to Mercurial.
   Matt
> http://mercurial.selenic.com/wiki/Subrepository
> http://mercurial.selenic.com/wiki/SubrepoRemappingPlan
> and maybe projrc:
> http://mercurial.selenic.com/wiki/ProjrcExtension?action=show&redirect=SubpathsExtension
> For what it's worth, I never liked petsc-dev being in a different folder
> than petsc-3.x. It is not confusing to have them all like so:
> petsc/petsc-3.1
> petsc/petsc-dev
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/4fcefcdc/attachment.html>
