[petsc-dev] petsc-dev on bitbucket
Sean Farley sean at mcs.anl.gov
Wed Feb 8 11:32:20 CST 2012
> No I mean I want
>   petsc/releases/petsc-3.1
>   petsc/tools/parsing/BarrysNewHTMLMunger
Sounds like you want a "traditional filesystem hierarchy" and like I said
before, your request will fall on deaf ears. This is the same request that
mercurial-dev gets from people switching from subversion: "I only want to
check out a subdirectory, not the whole project!" to which the common
response is, "You should rethink your 'project' if you only want a
subdirectory." Take a look at subrepos and subpaths:
http://mercurial.selenic.com/wiki/Subrepository
http://mercurial.selenic.com/wiki/SubrepoRemappingPlan
and maybe projrc:
http://mercurial.selenic.com/wiki/ProjrcExtension?action=show&redirect=SubpathsExtension
For what it's worth, I never liked petsc-dev being in a different folder
than petsc-3.x. It is not confusing to have them all like so:
petsc/petsc-3.1
petsc/petsc-dev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/f1d546db/attachment.html>
