[petsc-dev] [petsc-users] VECMPICUSP with ghosted vector
Mon Feb 6 13:27:13 CST 2012
On Mon, Feb 6, 2012 at 1:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 6, 2012, at 1:14 PM, Matthew Knepley wrote:
> > On Mon, Feb 6, 2012 at 1:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 6, 2012, at 12:47 PM, Jed Brown wrote:
> > > On Mon, Feb 6, 2012 at 21:42, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > I don't like this because it would mean calling VecSetUp() all over
> the place. Couldn't the ghosting flag be on the same
> > > level as the sizes?
> > > Maybe VecSetUp() is wrong because that would imply collective. This
> memory allocation is simple and need not be collective.
> > > Ghosting information is an array, so placing it in VecSetSizes() would
> seem unnatural to me. I wouldn't really want
> VecSetGhosts(Vec,PetscInt,const PetscInt*) to be order-dependent with
> respect to VecSetType(), but maybe the VecSetUp() would be too messy.
> >   Only some vectors support ghosting, so the usual PETSc way (like with
> KSPGMRESRestart()) is to calling the specific setting routines ONLY AFTER
> the type has been set.  Otherwise all kinds of oddball type specific stuff
> needs to be cached in the object and then pulled out later; possible but is
> that desirable? Who decides what can be set before the type and what can be
> set after? Having a single rule, anything appropriate for a subset of the
> types must be set after the type is set is a nice simple model.
> >   On the other hand you could argue that ALL vector types should support
> ghosting as a natural thing (with sequential vectors just have 0 length
> ghosts conceptually) then it would be desirable to allow setting the ghost
> information in any ordering.
> > I will argue this.
>    Ok, then just like VecSetSizes() we stash this information if given
> before the type is set and use it when the type is set.  However if it is
> set after the type is set (and after the sizes are set) then we need to
> destroy the old datastructure and build a new one which means messier code.
>   By instead actually allocating the data structure at VecSetUp() the code
> is cleaner because we never need to take down and rebuild a data structure
> and yet order doesn't matter.  Users WILL need to call VecSetUp() before
> VecSetValues() and possibly a few other things like they do with Mat now.
We just disallow setting it after the type, just like sizes. I don't see
the argument against this.
   Matt
>   Barry
> >   Sadly we now pretty much require MatSetUp() or a
> MatXXXSetPreallocation() to be called so why not always have VecSetUp()
> always called?
> > Because I don't think we need it and it is snother layer of complication
> for the user and us. I think
> > we could make it work where it was called automatically when necessary,
> but that adds another
> > headache for maintenance and extension.
> >     Matt
> >   We have not converged yet,
> >    Barry
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120206/9bca81f0/attachment.html>
