[petsc-dev] malloc_dump noise from threadcomm
Jed Brown
jedbrown at mcs.anl.gov
Sat Dec 8 18:20:02 CST 2012
On Sat, Dec 8, 2012 at 4:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I was thinking of just marking the first memory allocation for each
> object, like the PetscNew(struct tp,&(h) with a bool (another record in
> TRSPACE), then -malloc_dump_objects would be just like -malloc_dump except
> only dump memory with that mark and hence one dump for each object. Nothing
> fancy but get's the job done. Could have PetscNewMark() used for this
> purpose.
So just mark it with a Bool rather than the classid. That's fine, but the
extensible malloc interfaces need to be extended to support the extra
routine.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121208/ee4842fb/attachment.html>
