[petsc-dev] Fwd: rename SNES methods ls, tr etc
Anton Popov popov at uni-mainz.de
Sat Dec 8 17:27:38 CST 2012
On 12/6/12 7:30 PM, Jed Brown wrote:
> Matt and I have talked about this many, many times. Removing Dirichlet
> dofs entirely is inconvenient for structured grids and does not allow
> any data structure reuse in cases of phase change or similar where a
> node changes from Dirichlet to Neumann or vice-versa. It is also much
> less convenient for visualization because you need to embed the
> solution in the larger space before visualizing.
> I'm not a big fan of having two ways to do things, so since it's
> sometimes necessary, I usually recommend always leaving the Dirichlet
> dofs in using the procedure explained above. Regardless, the
> implementation is definitely not more complicated in defect correction
> mode than in "non-defect Picard". Dave May asserts that it is simpler
> to think about and to implement in defect correction mode.
> On Thu, Dec 6, 2012 at 8:39 AM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>     I know Jed likes this, but I think it is simpler to think about
>     the problem with
>     Dirichlet unknowns removed from the solve. We can do both.
Jed, Matt,
it's clear now
thanks!
Anton
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121209/f2ca8129/attachment.html>
