[petsc-dev] explaining hierarchical composible solvers
Sun Dec 2 18:48:10 CST 2012
In order to help explain and understand composible solver I started to add the PetscViewerDraw ability to the solver objects to graphically explain the solvers used and the decomposition of the solvers. It is very crude now but I've attached a couple of images of what are generated when using -ts/snes/ksp_view_draw   We need to add more information (somehow) to indicate  the multigrid levels as "levels" the field split decomposition etc. Any thoughts or code welcome.
   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121202/b60abec5/attachment.html>
Name: Unsaved Preview Document 2.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121202/b60abec5/attachment.png>
Name: Unsaved Preview Document.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121202/b60abec5/attachment-0001.png>
