[petsc-dev] rename SNES methods ls, tr etc
Peter Brune prbrune at gmail.com
Mon Dec 3 08:53:06 CST 2012
On Mon, Dec 3, 2012 at 7:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 3, 2012, at 12:40 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Fine with me, but it might be nice if the name could somehow convey that
> this is just a defect-correction iteration and need not be Newton (e.g.,
> it's Picard if a Picard linearization is used).
>     Picard is a weird beasty the way I implemented it.   Instead of having
> a "SNESType picard" one uses SNESType ls and then provides SNESSetPicard()
> (or local version of snessetpicard) instead of SNESSetFunction/Jacobian.
     We could change things to have a SNESType Picard and then have the
> user call SNESSetFunction() and SNESSet"Jacobian"() but the meaning of
> function and Jacobian are not the same as for Newton so that is not great.
>       We could add a SNESType Picard and then require the user to also
> call SNESSetPicard() to provide the Picard function and matrix. Then there
> is no confusing of setting a type of Newton but actually doing Picard.
> Internally the Picard snes type would behave just as the ls one does now
> handling Picard as a special case; in other words SNESType Picard is just
> an alias for Newton internally. But user is clearly using picard type. What
> do you think?
This would probably be for the best.  That way there is no confusion
between what people hard-code and the options they have to pass to the
solver.
- Peter
>    Barry
> > OTOH, the name "Newton" is much more recognizable...
> > On Sun, Dec 2, 2012 at 5:51 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sun, Dec 2, 2012 at 6:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >    Can we rename
> > > #define SNESLS           "ls"
> > > #define SNESTR           "tr"
> > > #define SNESVIRS         "virs"
> > > #define SNESVISS         "viss"
> > > to something like   newtonls newtontr vinewtonrs vinewtonss?
>  Suggestions for names?
> > +1
> >   Matt
> > >    Now that we have many other methods than Newton these names are
> terrible and confusing.
> > >    Thanks
> > >     Barry
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121203/03d12651/attachment.html>
