[petsc-dev] Lies in PCFieldSplit
Sun Dec 2 23:00:45 CST 2012
On Sun, Dec 2, 2012 at 10:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Jed, Matt, or I are responsible for what are likely lies in the field split naming terminology
>    We have
> const char *const PCFieldSplitSchurPreTypes[] = {"SELF","DIAG","USER","PCFieldSplitSchurPreType","PC_FIELDSPLIT_SCHUR_PRE_",0};
> Diag here actually means the A11 matrix, correct?
>     case PC_FIELDSPLIT_SCHUR_PRE_DIAG:
>       ierr = PetscViewerASCIIPrintf(viewer,"  Preconditioner for the Schur complement formed from the block diagonal part of A11\n");CHKERRQ(ierr);break;
>     case PC_FIELDSPLIT_SCHUR_PRE_USER:
>       if (jac->schur_user) {
> block diagonal part of A11 actually means A11, correct?  Otherwise what blocks????
Processor diagonal. This is not ASM where what we select is
automatically process diagonal.
   Matt
>    Once I get confirmation that these are phrased wrong I will update the source to be less confusing. Otherwise please example what diagonal means and how it is used here.
>     Thanks
>    Barry
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
