[petsc-dev] Potential memory issue with block jacobi preconditioner
Tue May 31 15:40:36 CDT 2011
On Tue, May 31, 2011 at 3:39 PM, fabien delalondre <delalf at scorec.rpi.edu>wrote:
> On Tue, May 31, 2011 at 4:35 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, May 31, 2011 at 3:31 PM, fabien delalondre <delalf at scorec.rpi.edu
>> > wrote:
>>> Hi All,
>>> I am trying to solve a problem for which we have a couple of 2D planes
>>> located along the toroidal direction. We are trying to use the block jacobi
>>> preconditioner where a block is computed for each 2D plane.
>>> When we use a number of blocks that is equal to the number of planes, the
>>> execution fails with the following message: "glibc detected" (both on PPPL (large
>>> memory Symetrical MultiProcessing (SMP) system with 80 CPUs and 440 GB of
>>> memory) and NERSC/Hopper machines). If we run the same test case with
>>> number of blocks = 0.5
>> Did you run this in debug mode? Sometimes the simple PETSc memory tracing
>> can catch things.
> Yes but I did not get anything useful so far.
It sounds like valgrind is the next logical step.
   Matt
> Fabien
>>    Matt
>>> (number of planes), it seems to run fine (although it's obviously slow).
>>> I ran Totalview/memscape on it and did not find anything useful so far (no
>>> memory leak or memory corruption detected). At this point I am not sure if
>>> the problem is on the petsc side or not. I am now trying to recompile
>>> everything on our local machines at scorec to use valgrind.
>>> The version I used on hopper is the petsc-dev version as of 031011
>>> compiled with mumps, hypre, scalapack, parmetis, superlu_dist, parmetis. The
>>> used compiler is the default compiler on hopper (pgi)
>>> Please let me know if you have any idea that could help me solving this
>>> problem.
>>> Thank you.
>>> Fabien
>>> Fabien Delalondre, PhD.
>>> Senior Research Associate, Scientific Computation Research Center
>>> (SCOREC).
>>> Rensselaer Polytechnic Institute (RPI), Troy, NY.
>>> Email: delalf at scorec.rpi.edu, Phone: (518)-276-8045
>> experiments lead.
>> -- Norbert Wiener
> Senior Research Associate, Scientific Computation Research Center (SCOREC).
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110531/4bf27187/attachment.html>
