[petsc-dev] Potential memory issue with block jacobi preconditioner
fabien delalondre delalf at scorec.rpi.edu
Tue May 31 15:39:25 CDT 2011
On Tue, May 31, 2011 at 4:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 31, 2011 at 3:31 PM, fabien delalondre <delalf at scorec.rpi.edu>wrote:
>> Hi All,
>> I am trying to solve a problem for which we have a couple of 2D planes
>> located along the toroidal direction. We are trying to use the block jacobi
>> preconditioner where a block is computed for each 2D plane.
>> When we use a number of blocks that is equal to the number of planes, the
>> execution fails with the following message: "glibc detected" (both on PPPL (large
>> memory Symetrical MultiProcessing (SMP) system with 80 CPUs and 440 GB of
>> memory) and NERSC/Hopper machines). If we run the same test case with
>> number of blocks = 0.5
> Did you run this in debug mode? Sometimes the simple PETSc memory tracing
> can catch things.
Yes but I did not get anything useful so far.
Fabien
>    Matt
>> (number of planes), it seems to run fine (although it's obviously slow). I
>> ran Totalview/memscape on it and did not find anything useful so far (no
>> memory leak or memory corruption detected). At this point I am not sure if
>> the problem is on the petsc side or not. I am now trying to recompile
>> everything on our local machines at scorec to use valgrind.
>> The version I used on hopper is the petsc-dev version as of 031011
>> compiled with mumps, hypre, scalapack, parmetis, superlu_dist, parmetis. The
>> used compiler is the default compiler on hopper (pgi)
>> Please let me know if you have any idea that could help me solving this
>> problem.
>> Thank you.
>> Fabien
>> Fabien Delalondre, PhD.
>> Senior Research Associate, Scientific Computation Research Center
>> (SCOREC).
>> Rensselaer Polytechnic Institute (RPI), Troy, NY.
>> Email: delalf at scorec.rpi.edu, Phone: (518)-276-8045
> experiments lead.
> -- Norbert Wiener
Senior Research Associate, Scientific Computation Research Center (SCOREC).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110531/a0e4bd67/attachment.html>
