[petsc-dev] attaching field information to PetscLayout?
Jed Brown jed at 59A2.org
Sat May 14 15:09:17 CDT 2011
On Sat, May 14, 2011 at 21:47, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Can these split ISs have communicators different from that of
> PetscLayout (this is something I use in GASM,
> for example)?
I guess I always thought of the field information in PetscLayout as having
semantic meaning to the user. I also thought these ISs would be strictly
non-overlapping and addressing locally owned values. In that context, there
is no particular disadvantage to always using global ISs, and I think it
would help keep the code simple. If you are going to solve part of the
problem on a sub-communicator, you can define that subcomm as all those
processes that have non-empty local part in the IS. If you have a huge
number of splits (such that individual splits on longer have semantic
meaning), then I think it is a different purpose.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110514/ca1f2070/attachment.html>
