[petsc-dev] preparing for a PETSc release
Blaise Bourdin bourdin at lsu.edu
Mon May 9 23:37:32 CDT 2011
Barry,
>>> is there any way I can reproduce the bugs without going through all that crap?
>> Let me see if I can build a Mesh from an exo file in C, and save it in a binary file, once MeshLoad is fixed, we can replicate the other bugs from there.
>   Ok, let's try that.
I am attaching 2 simple programs and a datafile.
Beam3B_s.dat was obtained using either the C or fortran program using 1 mpi task, reading an exo file and writing it to a file using DMView. I obtain a text file instead of a binary file, but I can read it back onto one cpu (use -mode 1). Distributed IO is broken.
Once we can save and load proper binary files, I will generate binary mesh files too.
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110509/fef5c83b/attachment.obj>
Type: application/applefile
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110509/fef5c83b/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110509/fef5c83b/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110509/fef5c83b/attachment-0002.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
