[petsc-dev] how to use builder.py
Sun May 1 12:18:42 CDT 2011
On Sun, May 1, 2011 at 12:08 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> It did not work with fiddling, but Jed's CMake stuff is doing the job, so
> I'll stick with that until it breaks :)
"Did not work" will not make it better. Send make.log.
   Matt
> A
> On Sun, May 1, 2011 at 7:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, May 1, 2011 at 4:59 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
>>> Is this documented anywhere?  It doesn't seem to do anything...
>> When run, it should build the entire package. There is a finer-grained
>> interface in builder2.py
>> but right now it has options problems on some machines.
>>   Matt
>>> A
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110501/a1857339/attachment.html>
