[petsc-dev] how to use builder.py
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Sun May 1 12:08:11 CDT 2011
It did not work with fiddling, but Jed's CMake stuff is doing the job, so
I'll stick with that until it breaks :)
A
On Sun, May 1, 2011 at 7:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 1, 2011 at 4:59 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
>> Is this documented anywhere?  It doesn't seem to do anything...
> When run, it should build the entire package. There is a finer-grained
> interface in builder2.py
> but right now it has options problems on some machines.
>   Matt
>> A
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110501/b3308c52/attachment.html>
